it's okay but you ideally want 200bhp to make it really fun to drive.
It's really lumpy at low revs in all gears but a little trooper above 2,5-3,000 rpm.
You don't half talk rubbish...
Outside of the JCW Models none of the Minis have 200bhp+, yet all of them are fun to drive.
I've owned an R56 Cooper S, and that was definitely "really fun to drive" despite having less than 200bhp, and I've driven an R56 Cooper which was just as fun to drive as the S (probably more so as you were less likely to do license losing speeds), and more recently I've driven a F55 5 Door Cooper D which whilst diesel was still fun to drive.
Anyway with regards to the original problem:
Seems to be quite a common problem, unfortunately with no real answers:
https://www.mini2.com/threads/car-laggy-hesitant-lumpy-driving-from-cold.169529
https://www.northamericanmotoring.c...01-r53-cooper-s-idle-troubles-re-visited.html
cooper s if you wanted proper fun. at least you didn't buy the diesel though.
the mini cooper s has 190 bhp which is 200 bhp rounded up
which is what i was getting at. i did say get the mini cooper s.
And the first gen (R53) had 168bhp, the second gen (R56) "only" 175bhp. Are these not "fun" or do you round them up as well????
the cooper and cooper d were like any normal car just smaller. the one was gutless. the cooper and cooper d would appear fun to anyone who has never driven a proper hot hatch.
first gen was smaller iirc so less weight probably around the same in terms of power to performance.
which is why i stated mini cooper s.
the cooper s was the proper hot hatch.
I just bought a 2005 Mini Cooper for a laugh, cost next to nowt and thought it could be fun.
Any suggestions welcome.
Thanks.
To answer the original question.... I wouldn't say it feels lumpy but I would agree that its quite gutless at low revs and likes to be held higher in the rev range when in fun mode. But I'd say thats the case for most older cars. Modern cars have much more low down grunt.
If its actually lumpy low down (by which I assume you mean, not very consistent response?) will be spark, fuel or air (intake and exhaust) related but you'd end up replacing loads of parts until something (maybe) fixes it as you'll notice I've just mentioned all the things that make combustion..... A reasonable plan would be to get the necessary tools/software to get the engine data up on your laptop, and take a look through the data. Should be able to start finding some clues.
Depends how lumpy it is whether its worth the faff. Good excuse to drive it harder and avoid the issue
Ignoring the point about whether we should round any hp number above 100 to 200..
I remember driving a Cooper a number of years ago. Thought it was bags of fun, and that was with the 130hp version.
IIRC, it wasn't lumpy, but was rather coarse. Not sure if the OP is referring to that.
If it is genuinely lumpy, then my suggestion is that you run it on non-supermarket fuel for a few weeks. I found that supermarket fuel made my MX5 feel rough low down. Changed to Shell (just the standard 95) and it smoothed out after a few weeks. I now run it only on Shell 95, and it's been perfect since.
Just agreed to buy a 2016 Cooper S, changing from my NC MX5, quite exciting to get into something more modern!
Picking it up next Saturday and then a long drive back from the North!
