Any monitor recommendations for colour accurate work?
1 Nov 2008
I'm currently using a 24" HP w2408h, however the colour seems to shift when I move my head.
I'm considering either buying the best value small screen that I can get with good colour reproduction to set next to it as a second monitor just for colour accurate work (ideally I'd like to do this to keep cost down).
Or alternatively possibly investing a bit more in 24/27" new screen with excellent colour reproduction and relegating my current monitor to be the secondary screen.
Once bought I'll be calibrating it with a Colour Munki and matching it up to print with my Z6100 large format printer.
Cost is important here, I'd rather only spend closer to £200 if I can as opposed to £500 if I can help it.
Does anyone have any advice or recommendations?
You could meet in the middle and go for a 27" Hazro when it's on offer. At some point the non-glass should come back to 350GBP, or you could take a punt on a cheaper B-grade (which I did myself and I am very happy, but I suppose it is a lottery). Alternatively, there is the 24" Dell monitors of course.
In descending order of goodness:
Dell U2410
Dell U2412M
Or if you're feeling really cheap and don't mind 1080p then get the 2312HM.
Sounds to me like the 12M is for you though.
