Any mouse similar or better than a Func MS-3 REV2
19 Dec 2010
I currently have the mouse in the thread title and I really like it. It suits my hand perfectly. It's starting to scroll on it's on sometimes. It's no big problem and doesn't annoy me at all, but, it's getting worse and I fear it's only a matter of time before other problems start happening.
I have it for nearly 6 years now, so it owes me nothing.
Is there any mouse out there that comes close in both size and shape?
I had the same issue when mine failed eventually.
An almost perfect replacement , for fit, is the Qpad 8k , but sadly discontinued, but still might be able to pick on up.
I settled eventually for the Roccat Nyth ( it has swapping side pieces, so you can widen it slightly to give that ring finger rest)
Thanks for the suggestions! I had read about the Qpad 8k, but they are hard to get, and not sure do I want to buy one second hand.
How are you finding the Roccat Nyth?
