Any multi-device keyboard recommendations?
1 Aug 2007
Hi all,
I’m after a native keyboard that switches between computers? This is so I can switch between a work and home computer and not require a second keyboard.
I’m not after one of the software solutions.
I was looking at the Logitech KS780.
My opinion would just be to get a KVM switch then you're not limited to ones with the functionality built in, you can use whatever keyboard you want. Also have the option of using the mouse between computers too.
Just bought a Dell premium keyboard and mouse set for this. Works perfectly.
Comes with a usb stick for the desktop and can Bluetooth to 2 other devices. Which device it goes with is selected by physical switch on the keyboard and mouse.
