Any other options to SG05 or SG07 ??
8 Apr 2011
Dunstable
Looking to do a build based on either SG05BB but is there anything of similar size that would fit a 2 slot graphics card ?
Similar size? There's the Lian Li Q11 at 17L but you only have 260mm of depth. Then there's the Lian Li Q08 with 345mm depth but then you're up to 21.3L in volume.
They all look a little too high for where I need to position it :(
So looks like the SG05/07 is my only option then
Thanks for the suggestions
I remembered Lan Gear Infinity a week ago, but not sure how easy it is to source (will be from abroad).
Apparently that is dead in the water. There was a big thread on it over on another forum but it died as the guy who makes the cases stopped posting and the website hasnt been updated for years.
SG07 is the way to go (or SG08). The Lian-li cases are nice but a touch big and not as well thought out as the Silverstones.
Thing about the Langear products, the way in which they've handled the whole design process doesn't instill confidence in me for their after-sales support.
I personally wouldn't give them my money.
People have complained about a stutter/freeze issue and a chirping noise with the 450W PSU. Silverstone recently posted about a fix they can do for it but it reads like they are masking the noise but nothing is said about the stutter/freeze issue talked about in the second link:
http://hardforum.com/showpost.php?p=1037594637&postcount=47
http://www.overclock.net/small-form-factor-systems/889834-silverstone-st45sf-total-crap.html
Might be why it can be found for £91 although I couldn't find it at that price lol.
I've had the SG05 450w for months now and never had a single problem, best mini-itx case until the SG08 imo :)
But you need the better cooling of the SG05 with a decent graphics card in it... plus it's cheaper. You can get the 450w version for £91!
It's cheaper yes (because the front panel is cheaper), but from what I've read I'm not sure the increased cooling of the 05 is significant, especially when considered next to the reduced noise levels of the SG06.
However if I was after the best vfm case that would play nicely with a 200W gpu and future proof me aginst upgrades, then yes looks and noise would come second to price and cooling :).
Incidentally, I got the 300W SG06 for £75 today only.
have seen the 300w today only - shame they haven't done the 450w version on that any time recently.
Think may be pushing it with the 300w using 15 2500k , hd6870 , ssd and 1tb sata
Yeah I think that might be pushing the boundaries of what you could expect to run reliably with the 300W PSU. It would probably work in the sense of it would boot and let you play games at stock, but overclocking would be a problem and the PSU fan would probably be on max constantly.
