Any owners of Dell Alienware AW3821 around for a question ?
27 May 2007
Front of the monitor
Hey all,
I seen it mentioned, but not been able to find any actually proof that this monitor that has gsync is actually also freesync enabled ?? So was wondering if any owners of said monitor might also be a owner of a AMD graphics card and can validate this rumor ?? I like the look of it and it is a tad cheaper then the LG monitor as well !
Thank you for reading and wish you all a Merry Christmas ! :D
I have seen confirmation that the screen does work with AMD, HOWEVER I have not seen any confirmation that it works in Adaptive Sync with an AMD. In other words I have not seen anywhere that it supports both Freesync and G-Sync. Alas I don't have an AMD card to test it.
I believe there's a few in the main thread
Thanks, found one user that says it working but not much more then that. That is if you referring to the New Alienware Q3 2020 thread ??
You don't have a mate with a AMD card you could borrow for an hour and check ? :p Sorry, just being bit cheeky there. :o Just that I could have it delivered tomorrow if I know for sure it's working properly on a AMD card. :p
Pretty much any g-sync ultimate monitor should support Freesync as it requires a new V2 g-sync module, for the rest of the regular g-sync monitor it depends on the module and firmware version it has.
How do you check if it has a V1 or V2 module ?
or do you mean all ultimate g-sync modules are v2 ? :confused:
As my monitor is an ultimate g-sync monitor
I believe ( and this is part of the confusion surrounding all of this ) the modules that have been dubbed as V2 support HDR, the others do not.
