- 30 Apr 2004
- Swansea
I'm looking at learning a bit about photography, but rather than getting a DSLR now, I was thinking of getting a small P+S camera that is easy to carry around with me, take some snaps, then get used to using various image manipulation packages, before I get a DSLR.
The P+S would then be good for everyday use, then use the DSLR when I know I'd be looking to take pictures.
So, are there any cameras that would suit my needs? The ability to record in RAW format would be nice as it would allow more posibilities when editing images, and possibly a few manual options so I could get the hang of a few features before migrating to something more serious.
Budget is flexible, but as always looking to spend as little as possible, but willing to spend more if you get more bang for the buck.
