Any point buying a 270mbps+ Router?
18 Sep 2007
Right. In the new year I plan to replace my BT Homehub, so i'm curently looking at my options. Personally my priorities are speed and stability rather than range.
What i would like to know is, if i dont use the wireless router as a network hub (ie i vary very rarely copy files across the home network), is there any need for 270mbps transfer speeds like you get on the new Netgear/Linksys?
When will ADSL speeds reach a point where the 54mbps standard speeds are the bottleneck?
The reason people buy N standards (270mbps) is because it supports HD streaming. On the standard wifi routers they will struggle to support the bandwidth needed.
