Any recommendations for car battery chargers/conditioners - also portable jump starters? Looks like I need both, assuming my 4yo battery isn't also beyond the point of no return.
I had a decent jump starter but it seems to have gone dead, I can't get it to charge anymore. Still that is my bad I guess. I only found this out when the car battery wouldn't start. It has dropped too low to start the car after a 2 month break in usage (which itself seems odd given the battery is only 3 years old, but I guess it doesn't get regular use so maybe it's to be expected).
Off I went to get the jump pack and despite saying 84% that too is dead. Warning beeps once I plugged in the jump leads. Went to charge it, it says 84% then after hitting 87% dropped down to 1%, got to 54% then I went to unplug it to move it to a different room and off the kitchen worktop whereupon the display went to "Lo" and nothing will budge it from that now whatever I try. You'd think it would have had a warning beep to charge it and prevent the lithium pack degrading into permanent 0%. Not best pleased. I guess the line in the manual about "jump unit life estimate 4-5 years" wasn't being pessimistic after all!
