Any recommends for a car android box
26 Apr 2004
Milton Keynes
Hi Guys, just got a BYD Seal, and it has quite a nice central 15" 1080p touchscreen - ideal for a bit of media if I'm parked up etc. In one of the recent updates it's had Youtube added, and a browser, but unfortunately it doesn't have the DRM required to add things like Netflix, Disney+, Prime Video etc.
I've seen quite a few mentions over the last few years of little android boxes which piggy back of wired or wireless carplay/android auto; but it seems a little bit of a minefield!
So - what I'm looking for is:
1)A little android box that can run Netflix/Prime Video/Disney+ for in the car
2)No issues with audio sync or choppy video playback
3)Ideally can output in 1080p and not limited to 480/720 via AA/CP
4)Has decent Wifi so won't struggle if I connect it to my phone's wifi hotspot
Anyone has one who can give feedback?
maybe it's a spoof product ... but video shows netflix&disney icons box can have it's own sim too,
don't know how they by-pass drm into the seal display.
In some of the very early versions of the Seal software you could basically access developer mode and sideload apps, but my understanding is that got removed some time ago. A native app would have been much preferable to an external box, but it is what it is - hence my search :)
I'll look into the one above as it sounds like the sort of thing I want.
I ended up ordering the Bruxe R6 after finding the website and videos from a site called Car Play Life; and reading through a ton of reviews and info on the net. One of the things they raised is that the more commonly available Carlinkit's and other units currently available use the 6225 Snapdragon and these seem to have some sort of software/firmware issue which impacts the smoothness of video playback (which is the primary reason I'm buying the thing, so an issue). Some of the older Carlinkits even from last year don't have this issue, but those are not as easy to find without having to order from China, and most of the commonly available boxes on the rainforest are either poor performing or can be problematic, so you kinda have to pick your poison. On top of that many of them are several generations old, and have weaker CPUs, 4GB vs 8GB of RAM with the newer units, and are generally more outdated; for not THAT much less money.
I went with the Bruxe R6 for a few reasons:
1) It seems to be one of the few 6225 boxes which doesn't exhibit this behaviour so it seems some actual development work has been put in.
2) The unit came second in his best Android car box of 2025 video, which was only recorded in the last month or so, and the video implied it gives the best video playback performance out of the 21+ boxes he'd tested (out of the ones of those that met his minimum criteria), coming second only to a machine with much worse video performance but a much stronger CPU for other tasks so basically won on a technicality, but that costs almost twice as much.
3) Video sync timing/sync was amongst the best he'd seen
4) Although I'm not fond of having to order internationally; as they have a US sales office, I feel a little more comfortable than having to deal direct with China/Aliexpress/Temu and the likes which is the case for many of these devices.
5) At ~£165 delivered after USD:GBP conversion, compared to the similar units on Amazon UK, its actually a decent chunk cheaper (albeit I did ALMOST order the unit that came 5th in his best of video, simply because it was available on Amazon UK and would have been here much more quickly)
6) Nicely Bruxe offer the unit with a remote if you specifically request it, which given I'll be pairing it with a car that has a large centre screen visible from the rear, the ability for me to tuck it away and control the unit from any of the passenger seats is actually a very positive feature.
I opted for the free shipping as I'm away for a few days end of the week, so the fact it'll take a little longer to arrive is actually beneficial, rather than me ordering for faster delivery and then it turning up whilst I'm away potentially!
I'll try and remember to update after the unit arrives.
PPS ordered with credit card so I have S75 protection just incase needed, never a bad thing when dealing with overseas, even if the companies involved are legit.
Interesting the bruxe video -
Seems it's connection to HU is wireless here - what protocol does it use to speak to HU, and which cars HU's work with it ?
(earlier AI ultra box had an hdmi out which would give zero lag if you had a compatible display)
Is audio quality as good as a CP/AA normal/direct connection protocol to HU ?
. can you hotspot the brux bruxe from your phone using it's data contract.
It uses Wired Carplay or Android Auto I believe :)
Yes you can connect it to your phone's wifi hotspot to use your phone for data :)
not sure , that had seemed logical, for highest speed connection, but his comment at 11minutes I then saw suggested wireless, in that video anyway ...
and maybe the usb-c connection is just for power.
if you can run an ip phone app like zoiper on the box, too (with a sim installed on it) you could make calls without needing your mobile at all, if the box is in a good position for it's 4g reception
I suppose people make calls with insta&fb too, though.
OK looks like they exploit wired carplay exclusively to connect with car HU,
can't see anyone saying you can load arbitrary Android apps onto the box though.
67e0f6f7acd93854e5eb5eb7_R6%20wireless%20android%20auto%20ai%20box.avif
I could be wrong, but based on everything I saw there and the manufacturers website, I BELIEVE it can connect via Wired Carplay or Android Auto, OR Wireless (but you have to configure it using wired first, which is why the car needs to support wired carplay, and then it'll just be powered via the USB as output will be wireless).
Afterwards you can then connect your phone to the R6 to run Wireless Android Auto/Carplay etc, or just via bluetooth to use it as an interface for calls etc, or give it it's own sim and use it independently.
Basically imagine it as an Android Tablet with additional options, that is piggybacking the cars Carplay/Android Auto interfaces to get access; so once you've got it running, you can then put a sim in it, tether it to a hotspot, and do voice calls etc through it as well. It has access to the Google Play Store so you can absolutely install additional apps :)
The reason I decided on this one though is the fact the video/audio sync is apparently so good for videos, which is exactly what I was looking for the device for, and also something I was worried about; cost shipped was £163 + any customs I get hit with, which for all this can potentially do, I'm pretty happy with.
[ does look like wired car-play is the back-bone for all systems like otocast too eg https://www.aliexpress.com/item/1005007747670079.htm ]
if manufacturers opened their ecosystem and provided an hdmi input to the display (with some safety precautions) or if the bare, hdmi to carplay dongles were beefed up with latest chipset,
that would allow people to either have a firestick or just connect a laptop/tablet when on roadtrips.
I've still not seen any explanation/video on how you add further apps to ai boxes ... I mean I'd put a better route planner on there too, for example
For the more advanced ones which are fully writeable, essentially just like you would an android tablet/phone. Provide internet to the box, go onto google play store, and download what you want :)w
Some of the more basic/dodgy ones require you to install from APKs, but a lot of the more fully featured ones have direct access to the Google Android app store.
@Alexrose1uk are you getting on with this?
@SamBGB
TLDR version: Yes - generally VERY well, and was definately worth the money paid.
Longer version:
It's not perfect; and it can struggle with some Youtube 1080p60 content due to the video conversion overhead, and the same goes for the new 1080p60 system wide refresh rate they added to the settings, albeit if you were willing to reduce its output quality in the system settings it might be useable, but at its default essentially 1080p30 display output, it'll play most streaming services pretty damn well with low audio latency; which is exactly what I wanted.
I cannot get Xbox Gamepass Streaming working on it (it loads, plays the Xbox logo, then goes to black screen before going back to the menu 10-20 seconds later as though its failed to negotiate the stream video), albeit it will happily accept bluetooth peripherals, I am suspecting its a conflict between the streaming requiring full 1080 output for most games, and the display apperture in my car is limited to ~1920x980 or similar due to my car's OS, certain apps dont work/display properly due to I guess a missing framework and Whatsapp didn't work until after a firmware update and me setting the display mode to basically zero scaling (I'm not sure if the firmware or the display setting changed fixed it, but it works now), but it's had 2 firmware updates this year already, and the support does respond, and will try to help.
Example of this is I requested the optional remote included with mine; mine arrived and unfortunately had a fault, so they sent me another aftermarket remote at thier cost which arrived a few weeks later; something I had to admit I was initially sceptical about.
I cant promise they'll continue to release firmware improvements, but it is at least a positive sign they have released some - more than I was expecting for a Chinese solution given how many of them are basically WYSIWYG.
They also worked with me on another physical issue, to reasonable satisfaction.
As with a lot of US/Chinese stuff though, be aware if the unit develops a fault after the initial 30 days I believe, you will need to pay to ship it back to them for a replacement/refund.
Either way though, Prime Video, basic Chrome usage, Youtube, Crunchyroll, Disney+ etc all work great, and that's exactly what its used for.
For the money I paid I'm very happy; it's not perfect, and I wish it was a little more powerful/had 5G connectivity, but for my primary use case (which is letting my wife watch stuff whilst I'm on the move) or me when I'm waiting somewhere, it's excellent. They have a microSD slot too, I've not checked the full hardware accelerated video playback capabilities reported, but you could also easily load up media onto a card, and play it using VLC (which comes preinstalled) or another player of your choice, which as long as you chose a HARDWARE playback compatible file type (so as not to add unecessary load on the CPU) will likely run flawlessly - I keep thinking I'll need to test that at some point but never get round to it!
Stuck an 80GB a month Three data sim in it too (4G only - no 5G modem in this and most similar boxes), so between that and my mobile hotspot, I've basically nearly always got data from one of the two sources as well.
The only other caveat is occasionally the box stalls up a bit, but I just installed a google play programme which gives me access to the OS reboot functionality, and that always seems to do the trick. Its been less of a requirement on newer firmware too.
The box essentially cost me around £150 after all conversions and such, and given how much use its already had in the last 5 months, it was 100% worth it.
Nicely if I move it to another car, it also goes through a whole interface detection thing, so you never get caught out with it being usable on a car with a different resolution display.
The only MAJOR caveat is your car MUST support wired carplay to do the initial setup; its possible to change it to wired android auto after, but it defaults to utilising the carplay interface.
