Any sage experts?
5 Oct 2004
Notts
I have to install Sage Payroll (networked) with 3 client's.
I've not messed around with Sage for years so need some help!
After I've isntalled Sage onto the Server and restored the data do I then istall the client PC's from the server or via the installation CD?
Then is it just a matter of pointing the clients to look at the data on the server?
Any help would be great.
Cheers,
OP :)
If I remember rightly you can just run "netsetup" from the PAYROLL directory on the server from each of the client PC's.
this should install the programme locally and set it up to use the relevant data folders too.
hope this helps
$c8t@
