Any SFF machines that will run 3 monitors?
5 Mar 2003
Swadlincote
Looking for something like the zotac z box but i want to be able to run 3 monitors. Are there any options out there?
I reckon unless you run a discrete GPU you may be out of luck.
Maybe a 5450 on an Atom board in a tiny case?
Oh and you'll probably only need one as the onboard should be able to run two screens, one via dvi/hdmi, the other via vga. Obviously depends on the machine but that's normally the case.
Yea accod's spot on, no sff machine like the eeebox or the zotac zbox support 3 screens out of the box.
The Usb adapters are a stopgap solution better used for document viewing and web browsing than video or gaming due to the compression and transfer accross usb 2.0 limitations in place.... But it will get you to 3 screens , or 4 or 5 depending on how many adapters you purchase.
But again, at 3 screens you are likely going to overstress such a small machine.
