Hi, hoping for any help with a little electrics at home.
I fitted an outside security light yesterday. There was an existing wire poking out of the wall under the eaves outside, and then a 2-gang 2way switch next to the back door. One of the switches works the back door inside light using 3core+earth (red+blue+yellow+green). The other switch wasnt connected to anything, but a wire was in the socket which appears to be the same as the one wired up to the outside light, which is a 2 core+ earth (red+black+green).
Here's a pic:-
From L-R - Blue=Switch1 Yellow=Neutral1 Red=Live1 Red+Black from 2nd wire I think go to the security light.
How can I wire up the outside light to work? Even if both lights will work off one switch that would be ok for now.
Thanks.
Here's a pic:-
Thanks.
