Any suggested improvements?
4 Aug 2013
I have everything else including a RM850 PSU.
My basket at Overclockers UK:
Total: £1,347.78
(includes shipping: £0.00)
Thx.
Thanks for the advice and quick reply.
Should be all I need to get it ordered, guessing the cooler you suggested is the better value and I dont need a H105 or paste :)
The cooler is good and easy to fit.
Comes with a little tube of paste, maybe enough for 2-3 attempts at fitting.
You could also go for one of these cases and white cooler,
https://forums.overclockers.co.uk/showpost.php?p=29650445&postcount=10
Maybe a black or white GPU,
Total: £1,239.93
Or if you fancy X99,
Total: £1,470.79
£70 cashback.
Edit,
That picture of the Gigabyte card might be incorrect.
http://wccftech.com/gigabyte-gtx-1070-windforce-oc-features-a-dual-fan-configuration/
Hey Stulid,
My order is still processing, think its waiting on the card to be in stock
1 x KFA2 GeForce GTX 1070 EX OC 8192MB GDDR5 PCI-Express Graphics Card= £374.99
Would this card, which is in stock now be a better replacement?
GeForce GTX 1070 GAMING X 8G 8192MB GDDR5 PCI-Express Graphics Card @ £429.95
Or the Gigabyte G1 for the same price.
Total: £429.95
