- 18 May 2010
Hi,
Noctua are releasing a Chromax version of this cooler soon and I'm limited to 153mm max height cooler so this fits the bill but with its 92mm fans and small stature even with 5 heat pipes crammed in I'm concerned its going to be loud and not be much better than the Wraith Prism that I'm using now.
Does anyone have any experience with it, if so on what CPU, are there any other coolers you can compare it to and how do you find the temps and noise?
Thanks
Thanks
