Any UltraBook users?
23 Dec 2010
Hey guys,
I am seriously considering purchasing an UltraBook and then throwing a Linux distribution on it (Most likely to be Ubuntu).
But from when I've used Ubuntu on laptops and other portable devices before I tend to find that the battery life tends to be nothing in comparison to if Windows was installed. I think this is a driver issue.
So does anyone here use a Linux distribution an a UltraBook, and if so how does the battery life fair?
Would have to agree with Disco Boy
If your main concerns seem to center around battery life v going the "Ultra" route
Surely you would be better off going the whole hog and going for something like the MacBook Air ?
The MacBook air is incredibly expensive.
And plus I've already stated that I'm not going to buy a Mac.
If you find the MBA incredibly expensive then I'd give up on getting an ultrabook. All the good ones are not much difference in price.
If you want an "ultrabook" that is fairly cheap then the Samsung Series 5 is probably the best you will get. Except it doesn't really fit any of the real ultra ultrabook specs - It's 14", twice as thick, has a DVD drive and a mechanical HDD...:p
There are also the Acer ultrabooks, but you get what you pay for with an Acer... Not very good...
I'd personally look at the UX31 and the Samsung Series 9 (new one) although the latter isn't classed as an ultrabook (even though it's the quintessential untrabook design), however both aren't much different in price to the MBA.
Plenty of power regressions have knocking about for over a year now in the current distros.
I think most of them have been addressed as of kernel version 3.3 not sure what 12.04 is based on.
You've clearly not seen the price of the proper Ultrabooks, have you? :)
They ain't netbooks.
I wasn't saying that they were in anyway cheap (I'm expecting to spend anywhere in the region of £700 - £1,100 on one of these badboys) and I would have ideally liked to put 12.04 on it.
I guess we'll have to wait for one of the big laptop manufacturers to start offloading laptops with a linux-distr pre-installed before we see any improvements.
The 128GB SSD 13" is well within your price range then... :confused:
And that's before HE discount...
