My neighbours wireless internet keeps interfering with mine. every so often it'll disconnect and try to connect to theirs instead. Mines listed as the default but it does it anyway
Also my signal seems really weak since it started interfering and the internets a lot slower. I guess I could change the channel of the wireless but I did that before and theirs still seems to be picked up on this channel!
Cheers
Also my signal seems really weak since it started interfering and the internets a lot slower. I guess I could change the channel of the wireless but I did that before and theirs still seems to be picked up on this channel!Cheers
