ANY WAY OF MAKING RAM SPEED BACK TO 6.6MB/S I GET LESS THAN 5MB/S UHH!
10 Jan 2006
Hi i did have problems getting 4 x pc4000 vx to work together at first "kept rebooting at winxp screen"found info on here now it all working i should tweak the setting i was giving as the memery bandwidth is 2mb/s lower than before
ill give you the settings i put in bios can you edit them to what would be faster as i dont know much about these settings ,at first when rebooting all settings was on auto except for 2.2.8.2
here they are:
genie screen
250
4
16 16
9
100
disable
1.450v
1.450V
Above VID 110%
1.30v
1.60v
3.3v
Dram Config
200
disable
2.0
02
08
02
10
16
02
03
02
03
1168, 1560, or 3120 but i used 2592 found that on another thread
auto
enabled
auto
0
Level 8
level 2
8ns
normal
6ns>>>>>>>>>>>>>somereason it was this for the rebooting set it to 5ns and it reboots :confused:
256
disable
16
04
disable
cant see why you lost the bandwidth. the timings look ok to me.
its only the command rate which is going to hit you hard but that has to be at 2t as its four sticks.
found the reason for rebooting after 20 reboots it was 6ns option [in the table above] 6ns works so auto must use something else i did each setting one at a time till it stopped rebooting at it stoped rebooting when i change it from 5ns to 6ns lol all that just couse a a setting fussy dfi's :D
anyway i try'd better timings but its not any faster
here something ill you its long so you have to scroll thru
first up will be 4 sticks
DMI:
DMI BIOS Vendor Phoenix Technologies, LTD
DMI BIOS Version 6.00 PG
DMI Motherboard Manufacturer DFI Corp,LTD
DMI Motherboard Product LP NF4 Series
DMI Motherboard Version 1.0
DMI Total / Free Memory Sockets 4 / 0
have to do it again to many images come up
last one now
sorry for all these had to ask if anybody can help i wouldnt of bought them if i new as they are going nearly the same as my bro twinmos cheepy's i feel a bit insulted :D
some value ram can run 2.2.2.5 @ 250mhz?
i did some further studie today and benchmark them one pair at a time,i booted up with just two and benched them written the speed down with 1T and 2T settings and there bot similar speeds for 1T to 2T with in window A64Info.exe
i have the memery i bought while my dud set was being rma they score higher than the set ocz gave me
set code ocz5001024eldcgevx
2-2-2-6 1T 7609 MB/s Memory Read forgot to do 2 t on these
2-2-2-6 1T 6459 MB/s Memory Write
2-2-2-6 1T 6315 MB/s Memory Copy
2-2-2-6 1T 38.6 ns Memory Latency
set code ocz ocz500512elgevx <<<different
now the return set:
2-2-2-6 2T 7512 MB/s Memory Read 2-2-2-6 1T 7612 MB/s
2-2-2-6 2T 5076 MB/s Memory Write 2-2-2-6 1T 6459 MB/s
2-2-2-6 2T 5465 MB/s Memory Copy 2-2-2-6 1T 6316 MB/s
2-2-2-6 2T 42.7 ns Memory Latency 2-2-2-6 1T 38.6 ns
So it seem alright
4 vx 2gb at 2t
2-2-2-6 CR2 7433 MB/s <<<<<<<<<<
2-2-2-6 CR2 4949 MB/s <<<<<<<<<<<<
2-2-2-6 CR2 5481 MB/s <<<<<<<<<<<
2-2-2-6 CR2 42.2 ns <<<<<<<<<<<<<,interesting it the similar as one pair on 2t
Im geting a new processor but i want to use 300 bus so would a Opteron 146 do 300bus? and can i use these on a devider with 300?till i get some ram
oh well
i was testing some advice i had to try 1/1 devider and 260
this is what i wrote on bleeding edge forum for ocz rma
-- SADLY MY 1 pair has died on me just by goeing to 260 ..
Ryder, Was going to 260 still in warranty?
i hope not i didnt expect it to die at ten mhz more ,it hit the yellow slot weird! didnt go for yellow and orange
can you "rma" sought me out again please
is there anychance you could do me a 2 gig pack ill send the others in!!
oh yeah that was at 3.3v at 2.5-3-3-8 as i thought it might be too much 2-2-2-8
im lucky the other didnt go getting nervouse then ,i thought i just heat so i cooled them and waited cleared the bios nothing beeeppp tried one pair at a time and went in but froze on nf4 logo and bits on screen like artifacts took one chip out the artifact were gone on this one but froze so i took that one out and tried one of the other pair that one worked went in bios save defaults and went in memtest and passed no.8 so i presume it ok took it out and tried the last one did the same passed now i thought put the all together again and went beeeep beeeep so there gone i presume
they did go in memtest at 260 and at 8 error flew up and froze didnt quickly enough shut it down ,i restarted beeep! beeep1 check the temps off them and they were roasting ,cook my sunday roast on that
has it been know to die at 10mhz than rated?
JUST UPDATING YA
:D
there fine now left them out for the night thinking there broke but i thought i will try "morning "them again and they worked 100% pass on memtest on all
got to of been heat as they were hot to handle :)
