Hey all,
I've just started using my Corsair K70 again, and it had suffered some water damage at some point (likely some blackcurrant I've spilt on it
It works perfectly, except the LEDS. As you can see from the image below, I set all keys to white, and some of the keys are not showing correctly. On these keys, some colours will work, others won't.
(Apologies for the dust, still needs a clean up
Is there anyway to fix this at all?
Thanks,
Marky
Edit: Sorry Dons, I misread the forum to be “Gaming Hardware” - Feel free to move if you think it should be
Thanks,
Marky
