any way to fix?
25 May 2011
I installed some software then realized half way through it was installing 3rd party software (norton security) so i cancelled. It was half way through the installation and every time windows starts the norton loads and I cant uninstall it or even close the tab..
Is there any way to get rid of it as its obviously not fully installed and worried it will mess up my laptop eventually. Hopefully I dont have to reinstall windows. I dont have a system restore point as had it turned off
Restore from your backup image.. because everyone has one, right?
Norton Removal Tool should see you right.
