Any way to make headset louder?
Possibly? Illdp some research. Having read up it cpuld be something to do with the impedance and that a mix amp might help with this. Althligh i dont really understand it all
If your headset is plugged into the controller, then you need to adjust the options for the controller as well. I bought a HyperX Cloud Alpha Pro and it was really low volume even with the dial turned up on the headset. After a bit of searching, I discovered you have to go into the devices menu in the Xbox settings menu, select your controller and then adjust the volume options in there.
https://www.reddit.com/r/xboxone/comments/3dei9z/tech_headset_volume_too_low_on_new_controller/
Glad I stumbled into this thread! Mine's very quiet too and now I know why. Thanks guys.
