- 2 Sep 2013
Have been slowly silencing my system bit by bit, and I "think" I've now done everything possible to silence or reduce the noise of my existing gear as possible. And I "think" I've narrowed the remaining items down to two remaining sections that require something more (that I can't do anything about) just yet, but I believe it is everything. Just wanted to see if anyone can see anything I've missed out on tweaking or ghetto modding further to reduce the noise being produced to as little as possible. The aim of the system is to have all the computing components running at the most energy efficient level (so at the fastest level using the least energy) whilst also having it as silent and cool as possible (with silence more important than cool). So basically the impossible in most cases.
So the system:
Corsair Obsidian 650D (Ghetto modded)
Asus Rampage IV Extreme (Original version)
Intel i7 4930k @4.3Ghz
Corsair 64GB (Dominator and Vengeance) DDR3 1600Mhz RAM
Powercolor Red Devil RX580 (reapplied thermal paste)
Corsair HX650 Bronze PSU
Corsair 650D Ghetto modded
Cut out 200mm fan grill at the front, placed cable sheath plastic over the remaining sharp edges to reduce noise made from air rushing over them.
Cut out 120mm fan grill at the back, placed cable sheath plastic over the remaining sharp edges to reduce noise made from air rushing over them.
Top grill has an A4 pad of 150 odd leaves remianing placed on top to cover it up, preventing sound from escaping from the top of the case.
Front 5.25" Bay covers removed and empited out to place extra fan there. Dust filter attached to the former location of the slot covers.
Side Panels have duct tape taped to the edges to prevent direct transfer of vibration from case to panels.
PSU seating (raised metal struts in the case location for the PSU) has some duct tape applied to raise any PSU fitted in there a tiny amount so as to reduce gap between PSU and case (and vibration from PSU to case, etc)
Removed the top external HDD tray.
Cooling in use
Noctua NH U12A on CPU. Fans set to Exhaust out towards the back. Connected to CPU Fan Header. Set to 50% at CPU 50C and to raise to 60% at 70C, and 100% at 75C+ (as per BIOS settings).
Noctua A12x25 in Rear Fan Slot set to Exhaust. Connected to CPU Optional Fan Header. So slaved to copy all CPU Fan settings.
Noctua A12x25 in 5.25" Bay set as Intake. Sides ghetto taped up to prevent recycling of air there. Also connected to CPU Optional Fan Header. So slaved to copy all CPU Fan settings also.
Noctua A20 in front 200mm Fan Slot. Set to static 60% Fan speed in BIOS PWM settings (for least amount of detectable sound vs highest operating RPM)
Noctua A12x25 in PCI slot set as Exhaust. Set to static 50% Fan speed in BIOS PWM settings (lowest setting it can go unfortunately).
Noctua A14 sitting between the end of the 5.25" Drive Bay and the GPU (at height of the lower half of the case, so between the A20 at the front and the A12x25 at the PCI slot) set to provide increased airflow inside case. Set to static 60% Fan speed in BIOS PWM settings (lowest possible without producing detectable noise).
Rough temps in play right now
Room Temp: ~ 25C
CPU: Idle ~27C, Load ~64C, AVX Load ~72C, Gaming Load ~53C
GPU: Idle ~33C, Load ~83C
GPU VRM: Idle ~40C, Load ~90C
GPU Fan: 0%, Heating up (from 60C) 35% flat to throttle temps (90C)
The system is currently sitting under the desk in an open desk. So basically the sound echoes around easily as there's not a lot stopping it. There's a wall to the left of the desk less than 6 inches away from the back of the case, and the back of the desk is less than 18 inches to a wall, both of these return the echo of the fans and "thwipping" sound quite noticably during the night. But imperceivable during the day.
I don't have a sound meter so I can't really tell you how much noise it's currently at. But testing during the middle of the night, the sound from the back of the case, is akin to a car engine left on, approximately 30-45m away. So you can barely hear it, but you can notice this very low frequency "thwipping" type of sound when you put your head down towards the case. It's "there", but you can't necessarily tell where. That type of volume is what is being emanated to my ears.
1. I believe this "thwipping" sound to be emanating from the PSU fan or the PSU itself. And I think the only solution really is to go Fanless PSU and hope no sound from the rest of the components, or to put it into enclouse with sound dampening materials to reduce the remaining sound from it. Correct?
2. The final piece of the sytem making a sound is the fans escaping out the back of the case and echoing around. I'm thinking this part absolutely requires me to place the computer into an enclosure of some type (that has been fitted with sound dampening material) to dampen the escaping sound further and there's no other option, right?
3. Sound dampening foam for inside the case isn't going to help here correct?
Any other ideas and thoughts, totally happy to tender.
Thanks all.
So the system:
Cooling in use
Room Temp: ~ 25C
Thanks all.
