Any way to tell if ** really using 1T command for mem
24 Oct 2005
North East
I have asus a8v deluxe rev 2 It has
2T Command (disabled) which should make it 1T. However theres no performance increase except 100 points i think in pc mark 04. Is that the major boost im supose to be getting lol as the way people go on about it i thought about 200 points ore 300 i would get with it on.
Any windows based tool i can check if its using it or not?
Btw using Geil Value 2gb pc 3200 @ 2.5,3,3,8 (seems to run ok) or should i go back to 3,3,3,8?
Use 'Prime95' to check if it's running 'alright'. Prime will stress your system and will tell you if it's not happy.
A couple of free benchmarking tools...Everest home edition is useful as it'll give you details about your hardware, but most importantly for you it includes some memory benchmarks. As does Sisoft Sandra. Use both/either to see how changing settings affects memory performance.
For real world testing try Superpi mod 1.4. It's a good'un.
SiSoft Sandra memory benchmark should be able to detect the difference between 1T and 2T, gaming wise I found it only made a couple of percent difference to average frame rates, but with 2T the lowest FPS was much lower.
Jokester
