- 13 Sep 2003
- Glocestershire
I'm a bit stuck with WininstallLE.
I'm trying to write a package from scratch, very simple, two reg entries and one file and I can't do either.
I can add the file to the MSI but I can't work out how to set the target directory.
Secondly when I look at the registry section and it shows the four HKEY doofers. How do I add keys further down the tree. If I use add key to recreate all the levels of the tree and get permissions errors when I try and run the MSI. I need to add one key to an existing tree.
