Recently ordered the above AIO GPU cooler. It has not arrived yet but I am hoping to get over this hurdle before I install it.
Looking through instructions and various other threads for a way to control fan speed based on GPU temp.
Is this possible as it looks like you have to use a custom fan curve with software/bios based off liquid temp or PCI-E 16X temp which isn't really ideal. Could I hook up the Gelid PWM Adaptor direct onto the GPU (6900XT Ref) and daisy chain the 3 Rad fans into that with a Y splitter.
So really, my question is. Is this possible?
Has anyone done it?.
Will I burn out the header on the GPU?..
Thanks.
Thanks.
