Anyone Able To Help Me With BitFenix Spectre Fans?
18 Sep 2011
Hi,
I recently recieved 4 red spectre 120mm fans from OCUK and they have the usual 3 pin connector but also a 2 pin connector for the LED.
Where does this LED pin go? I have a Crosshair IV 890fx Board
Thanks
Thanks just read that article, I think the controller allows you to turn the led's of and on but it says they can be used with jumper selectable on/off. I think I just need to find some spare pins on the board!
Just been reading an article, I think maybe the extra wire that comes with it is for hydra connection, the led's are actually powered by the 3 pin.
Ill try this over the weekend!
Thanks
