Anyone added fans to their Antec 300?
5 Aug 2006
Derbyshire
I have an Antec 300 with the rig from my sig, with only the fans that come with it on low (so they are quiet).
My cpu idle is 55c (the fan ramps up at 60 and under load it hovers around 65).
Would adding 2 front fans and/or a side fan make much difference to temps?
the only fans moving air in or out of the case at the moment are the 2 exhaust ones and my 4890.
Id add at least one front intake fan, that way you have continous airflow through the case, ive never really seen much benefit personally from using sidefans.
Ive added all but the side case fan with Akasa 120mm fans and the rubber mounts, my E8500 overclocked runs around 50c full load
What is it overclocked too?
I can get windows boot with 3.6ghz but it is HOT, as in it was not far off 100c in intel burn which is obviously far far too high. The cpu fan was on max but I was thinking the exhuast fans are having to suck air through the case as there are no intake fans.
I use 2 intake fans, both 1200rpm (after market blue led ones), and the standard 140 fan up top that came with the case on mid setting, and a 1900 rpm scythe juni on my water radiator thats on the outside of my case, that is set to pull air from the radiator, so takes some, but not a lot of air from the case.
The main reason i use 2 intake fans are 2 fold, the bottom front intake mainly cools my hard drive, as i have placed the drive in the 2nd bottom slot, so that the air goes over and under it. the top front intake is for air to directly enter the rest of the case.
The 3 case fans are hooked up to a fan controller, and only on hot days are they set to max.
My temps today have been as follows
Cpu idle 30c Gaming 39/41c Prime/Occt 49/52c Occt Linpack 60c
Chipset ranging from 28c idle up to 31/32c gaming and 35c under heavy sustained load.
Hard drives been a steady 18C all day, mainly due to samsung F1s running cool, and the fan mentioned above.
these are all from my system in my sig, please note that my cpu is water cooled, but it is low end water, so more or less like having a high end air cooler.
About the side fan, i used it for abit then tested without, it really did'nt make much difference to my temps, so i blocked up that fan intake there.
So to answer u question i would adivise atleast 1 intake, if only to have cooler air going under/over your hard drive.
Quick edit:
I would also advise against using intel burn test, intel themselves has stated that it adds far to much pressure to there cpu's.
