I built up my new system a few weeks ago. Today, I installed a m.2 NVME drive and after starting back up again I've noticed my onboad audio is no longer working....
I've pulled everything out that I can (GPU, m.2 drive, all other hard drives, unecessary front audio and usb connectors etc) and tested it up on my bench away from the case. The problem persists. I even did a 100% clean fresh install of Win10 on a spare drive. Same results.
The audio driver is loaded just as before but when I test any of the outputs (clicking on the speaker images in the Realtek control panel) I just get a dull thud and a little static. No audio from any other source either...
The board is an MSI MAG Tomahawk Z490
