24 Aug 2007 at 00:31 #1 fonzio fonzio Associate Joined 26 Jul 2007 Posts 45 just the blacks are ruining this monitor for me, did the 2407 suffer from this too? if so can you say what you used to calibrate thanks fonzio
24 Aug 2007 at 08:58 #2 Sallermas Sallermas Associate Joined 30 May 2006 Posts 266 I calibrated my 2407WFP-HC settings with SuperCal and the profile it generated differs considerably from the previous A04 The onscreen interface has improved too - for example, the new one has a contrast control which the old one didn't.
24 Aug 2007 at 10:50 #3 Sallermas Sallermas Associate Joined 30 May 2006 Posts 266 http://www.northlight-images.co.uk/viewing.html#monitor_calibration
25 Aug 2007 at 00:15 #4 fonzio fonzio Associate OP Joined 26 Jul 2007 Posts 45 Sallermas said: http://www.northlight-images.co.uk/viewing.html#monitor_calibration Click to expand... wow thanks helped a lot, at least until i save for a hardware calibrator if you are suffering ghosting then this page will help or did for me, dunno *** ** settings after cal are but im sure you can apply them http://www.pretentiousname.com/dell2407fix/index.html hope this helps and thanks again fonzio
