Basically:
1. I turn on my computer, but nothing is displayed on the monitor, the motherboard doesn't load the BIOS
2. I then switch the computer off then back on again
3. The motherboard loads the Asus bios as normal but I get the "overclocking failed" screen, it tells me to press F1 so I do that
4. It takes me to the BIOS where I go into AI tweak and check the overclock settings are still there, I then hit "save changes and reset"
5. The computer restarts and loads Windows like normal
This happens EVERY single time..at first I thought it was normal with the new motherboards (I have an Asus P8P67) but it's annoying me now.
I've also had a few blue screens as of late and was wondering if that's got to do with this.
So does anyone know why this is happening and can help me fix this problem?
Cheers
Cheers
