Anyone else having constant audio out of sync issues with Sky Q?
25 May 2011
The only thing I have learnt to fix it is rewind 1 sec and press play which fixes it.... Setting forced audio delay doesn't work as the sync changes all the time.
My remote at least once a day looses connection as well and I'm forced to pull the plug out the back.... Holding 1 an 3 doesn't fix
I can only get 8bit 2160p rather than my TV supported 10 bit, all though using 20m hdmi
Have you pulled any HDMI out of your amp without turning it off?
Have you tried resetting your amp and/or sky box?
Your tv likely isn't a true 10bit panel.
I have always had occassional voice sync issues with Sky, not just Q, I think Q is better as it is easier to correct by a quick rewind or stop/start.
Andi.
