With all the motherboard fan control options nowadays built in, you can get a pretty silent air system for general use. The only time it starts making noise is if gaming or doing something intensive like video rendering.
For me the fact that my system always makes as little noise while gaming as it does when idle is enough justification for the extra few hours it takes at upgrade time.
I suppose some of us are more bothered by noise than others.
I had a FT02, in fact it was the case I bought when I tried to give up watercooling for much the same reasons as you have and while I agree the 180mm fans are very quiet unfortunately at the time at least there wasn't a GPU available with anywhere near silent fans when gaming.Can't you get the fans to shut off. I suppose my setup helps (FT02 case with the 3 x 180mm fans in the bottom) as I have the fans on a super low speed that I can't tell if they're on but they still push some air, and the heat naturally exhausts upwards.
TBH I can't hear anything unless I really try (desk is on the floor) and replacing the HDD with an SSD has made it even quieter.
As for the noise whilst gaming, most of the time (although it depends on the game) the game sound drowns out any higher fan speed, so it's not a huge issue again.
My PC sits on the desk about 60cm away so I find any case noise to be annoying even with game audio, maybe I should just turn it up but then it would still annoy me when there is quiet moments in the game.
It may take longer to upgrade my PC but once it's done I know I can game in silence for months and months ahead.
Also I actually enjoy the process of putting a loop in a new case, it's fun figuring out the best place to put things and make the cleanest loop.
Do near silent GPU's exist now? I mean I have an EVGA ACX one which doens't spin the fans until it gets warm which adds to the silence, but I do notice the difference in noise when a game's loaded.
I did enjoy the planning process when I did my first loop, but lost it somewhere along the way (probably during the maintenance parts and upgrading). I also hated having my PC offline for long periods and never had a backup one to use.
Yeah exactly, I had an EK fitting (That I got new) almost take out my TXP, and has stained the cream carpet in the office (Red coolant)
A lot of these issues are put forward as anecdotal evidence, but how many of these issues are created by installation errors? We're relying on the person who is potentially at fault to own up to that, and let's be honest...
