Anyone else regret going full water ?
Sgarrista
Commissario
9 Aug 2013
Bromsgrove
Having had to replace 4 dead graphics cards, going hardline has been an absolute bitch. I would probably cry if needed to remove the CPU block.
6 Jan 2013
Rollergirl
I'm not going to bother with my CPU in my upcoming loop. The HSF doesn't make any more noise than the rad fans and I'm happy with 4.4Ghz with temperatures below 70C on air as I won't be pushing for any more.
It's the GPU that needs the liquid cooling, and I wouldn't touch AIO coolers. I think I'll add a facility to swap the GPU easily too, because as soon as Nvidia come up with the next best thing I'll be on it!
Sgarrista
Commissario
9 Aug 2013
Bromsgrove
This is the current state while another dead titan is off to RMA:
27 Aug 2011
Sheffield, UK
I've been running under water for a few years now, currently I'm quite happy with it, but I do go through stints of regret, like every 6 months, when I dismantle everything, clean it, and replace the piping. I am slowly taking steps to make this less labour intensive e.g. drainage port. but it's still an arse and it leaves me without a computer for at least a day because I never plan well enough in advance to order new tubing
28 May 2010
London, UK
Been under water for nearly 7 years and recently went Air. Because I upgraded to a 1070 from 290. To my surprise it is actually less noise than water cooled!
Admittedly I had 2 x D5 pumps, which were not de coupled as I would have liked, which kind of made a vibration off the case.
Currently CPU is cooled by K2 mount doom and strix stock air cooler is silent on load as well. Ideal temps are about 2c high load about 5c high on CPU and 15c on GPU(GPU gets to 60c on full load but that is well with in the range) - so far I am impressed by air cooling. Mount doom is not exactly a "small" cooler though. Still keeping the same GT1450 fans(3x on top and 2 x in front) in the case.
Air is a temp measure anyway, till I resort a full cover block for 1070 strix :) I will properly mount the pumps next time so that they don't touch the case or any other component. In my previous case(TJ07) I had a single D5 "floating from tubing which kind of absorbed the vibrations and did not make any sound.
In other words; no I do not regreat it and will do again, but that's just because I can and have almost all the parts, high end air when done properly makes the same results.
6 Jan 2013
Rollergirl
As mentioned a few posts up, I'm really starting to realise that a decent air cooler on the CPU will be just as good as a custom loop for gaming systems. In systems that will push the CPU 100% for extended periods or systems that are heavily overclocked then water will make a difference, but for mild OC'd gaming rig it's unnecessary.
GPU's are totally different. I'm a big fan of the Gigabyte Windforce cooler, but even that will be put in it's place with a full cover block within a custom loop (AIO on GPU's are a waste of time IMO).
24 Aug 2013
Lincolnshire
+1
I'm getting the same temps and clocks with an AIO than I was with a custom loop.
GPU blocks are good at keeping them cool and the clocks up. But my ref Ti's had horrid whine so in the end was louder than the original blower.
Can't fault my Air cooled Gaming X. Quiet as my custom loop and maintains 2025mhz 24/7. 25mhz lost over custom loop. Minimal whine too.
2 Feb 2012
ive been on water since the days of the first thermaltake all in one water systems and wouldnt go back thru choice. i just find it more fun to build systems with custom stuff than run of the mill options.
i like big external loops outside of the box. yes its more fidlly when you make changes to your system but thats part of the build fun imo.
22 Dec 2013
I'm going back to "air", AIO CPU and aftermarket GPU. Have had multiple EK 90deg fittings fail on me, fortunately none of which took any hardware with them. I've come into some money so upgrading a few bits and going back to air for the mean time.
Will definitely revisit custom loops in the coming years once I completely upgrade to a new build, so no regrets.
13 Feb 2014
I'm going back to "air", Have had multiple EK 90deg fittings fail on me.
Woah EK really are getting a kicking recently.
That's 4 people I've seen posts by with issues some EK Predator, Failing rad , Dodgy GPU Block and now fittings.
Wouldn't wanna be their RMA department..
17 Jun 2007
Any of you guys running samsung smartthings.
They do a moisture sensor that you could put in your case which would warn of increased humidity or moisture as an early warning.
I've been considering watercooling. But only really for the nice tidy look inside the case.
I've noticed that a few posters have said about dismantalling and cleaning every 6 months.....Is that because of OCD or do you actually have too.
Man of Honour
12 Jul 2005
Aberlour, NE Scotland
You don't need to and I think it's just overkill. I have gone two and a half years between drainings and suffered no ill effects. Most premix fluids these days are recommended to be replaced every 12 months but if everything is ok I usually string it out to 18 months or so.
3 Aug 2006
It does need to be looked at in perspective, they are one of if not the biggest name these days in watercooling so I'd expect to see more problems with their kit than other brands.
I've bought dozens of different EK parts over the years and only had problems with a very small number of them.
The level of problems I've had hasn't stopped me buying more of their kit since and probably won't in the future either.
6 Jan 2013
Rollergirl
I'm going to be using some 90 degree EK fittings in my next build. Seeing as there's a few tales of failure here, could I ask are these fittings failing after passing leak tests? Or, are they failing during leak test?
My concern is that I'm putting something together that will be failing after a period of time, which gives me no chance of predicting.
I'm still able to return my 1080ti block and back plate but would rather keep.
22 Dec 2013
My loop is entirely EK, blocks, fittings, res the whole shebang. I've only had issues with 2 90 degree fittings, post leak test. There's 7 of them in my build that I've been running for 2 years now so take from that what you will.
