Anyone else struggling to Nvidia shadowplay to work in Fortnite?
3 Oct 2012
This used to work fine, but after the recent updates no longer works, yet it still works fine with PUBG.
If I start a recording manually in Fortnite it does that all fine, but the eliminations and deaths (for which I still receive an icon in game telling me are being saved) no longer appear in a menu after the game to allow me to view and save to gallery.
I have tried re-installing the Geforce Experience, I have loaded the latest Nvidia drivers and I have turned shadowplay off and on in the settings both in Geforce and the game (as well as the normal in game replay feature) but all to no avail. It's driving me a bit crazy because I don't always remember to start the recording manually and I have already failed to record a nice kill streak (of two, which is good for me!).
Can anyone please help?
Whilst I was unable to fix this I did find the clips were still being placed in the temp folder and the Fortnite sub folder in there, so if anyone else is having these problems hopefully this helps.
GeForce highlights that I’m assuming your taking about with the eliminations / mills is a useless piece of software atm it’s so unreliable you are better off just having shadowplay set up so you can save the last 5 minutes and capture the video that way instead.
