anyone else using the 780g chipset?
12 Jun 2008
i bought a mobo with it recently, but to use AMD overdrive i need to update to the latest bios version
i tried this before but the update didnt work, and i had to eventually RMA the board
so has anyone done this successfully, and if so what methods did you use? i tried it from the BIOS, and i was using a floppy with the new BIOS image on it (risky i guess - but i didnt know how else to do it)
any help would be appreciated, as i really want to start using AMD overdrive, all of the other overclocking tools seem a bit sub-par compared to it
thanks
For my gigabyte 780g motherboard I put the bios file on to a USB memory stick and loaded up Qflash through the bios.
I always make sure i'm running everything at stock speeds before updating, just to be on the safe side.
