you usually find that with case fans though, you never really hear of people using them, they just swap them with better ones that push more air and are a lot quieter
I had a browse through youtube earlier to see what people had done with theirs on air and many seem to swap out the side and top fan for 120mm's items (2 at the top and 4 on the side). I may do this with mine i was just wondering if anyone else had done this to their haf 932 case and if it was a worthwhile upgrade in terms of airflow over the stock fans.
The big fans are fine in my 922, I run them at a low voltage and they shift more than enough air and make next to no noise. The 120mm fan they provide in the 922 was a bit lame however so I changed that and added some more of my own.
