I'm getting a really slow connection to most sites right now, with quite a lot of sites totally uncontactable! OCUK works good as does google.co.uk but practically all .com sites are unreachable. Anyone else experiencing problems?
Angus-Higgins said:Try "Repair" on the connection?
It could be the ISP; it has happened to me before.
Angus Higgins
starscream said:I heard the internet server had to be rebooted earlier today.
Correct.ElRazur said:A guess....Tiscali or NTL![]()
DeeJay-Mo said:I'm connecting through a router, so there's no "repair" function. I could just try switching eberything off and back on again which would have the same effect. I'll try that and see if it helps.
Yeah I could repair the LAN connection to the router if I wanted, but I don't think that's the problem. I'm getting good pings to the router.Angus-Higgins said:If you are in Windows XP is it not on the context menu for the connection to the router in the Network Connections window?
Guess it's not just me then.$loth said:I'm with NTL and it was going quite slow a moment ago, I exited out of azureus and it still did it.
DeeJay-Mo said:Guess it's not just me then.
