Anyone ever built a shed?
31 Oct 2002
Got one on order for the garden and wondered what I need to do about the base - I read either concrete or paving slabs but does anyone have any experience with this - what's the best options?
me and my dad built shed couple years ago it just went onto patio to be honest and its fine although thinking bout it might be worth proping the bas up onto patio tiles or summin like that so the bas isnt touching floor stops water getting at it and causing rot.
You need two people to build it really. As for the base I would elevate it from the ground otherwise the floor will rot quicker. We used treated sleepers and concrete blocks, so roughly 6" from the ground.
This looks like a pretty good guide for the concrete base, I think I'll follow this - as it's going to be the other side of the garden from the patio it will need a concrete base (could do with just slabs but figure I'll go with this guide).
I helped my Dad build a metal one.
****ing piece of crap took a whole day to assemble, shredded my fingers to pieces and became the world's largest spider nest in the space of a week.
I don't like sheds. They suck.
That B&Q guide pretty much goes through how I've always done bases at work. Concrete isn't that hard to knock up although you do need a mixer. Make sure the whole base is level and square. This way guarantees a perfect job although is a little tricky if you're a beginner.
I'll get my Dad to help out with the base as he has laid concrete before, I always remember him mixing it on an empty concrete bag, but this was the 70's! Can you get away without a mixer for a small amount?
Remover 4-5" of earth and roughly level, then get some rubble or broken bricks (either from you garden, tip or builders skip if you ask they wont care!) Then get some wood planks and lay the upright around the edge and hold them in place with wooden pegs on the outside. Get the wood so that there is about 1" above the gound so that if it rains heavily the base wont get drenched in standing water. Then make up concrete* and pour over the bricks in one go and smooth. Then put shed ontop.
Also if its say a 6x3ft then dont do a 6x3 base do it slightly larger. Oh and if you can have a slight slope to aid water exiting the base..
*For the bottem bits use a mix of 50/50 concrete/chipping or gravel and then top of with a thin layer of just concrete so its easier to smooth. To mix it just get a bit of cheap wood (ie mdf) and lay it done and mix it on that unless you doing a garage sized shed!
Hope that all made sense..
I had exactly the same experience with mine!
I also overordered the concrete for the base and ended up with an 18" deep foundation for a flimsy metal shed!
Dig a plot just longer and wider than the shed, about 6" to 12" deep, line the bottom with sand/gravel for about 2", pack it down tightly, then fill with concrete. Level it with a plank before it dries, and Robert is nobbing your mother's sister.
Me and my mates built a shed years ago for my mum, with the promise of a 24 pack of beer for payment :D . There was a massive bonfire down the road so we robbed a load of crates and built a pretty respectable shed :) . My mum was chuffed with it and its still standing to this day. Its now the home for my bike. We just built it on bricks ontop of the lawn lol, its not sunk though.
It's good to concrete but its a PITA in that it takes time and is fairly hard labour. Also buy the best quality shed you can and in my opinion go for wood over flimsy metal. I bought one called the Storemore Trentdale in thin metal and it was a nightmare. Ended up binning £400 of twisted poo quality metal. Now have a nicely concreted corner of my garden with nothing to put on it. Saving up for an £800 wooden effort and probably getting a pro to install it as I can't face the pain again :o
