Anyone experiencing trouble with IE7 ?
18 Oct 2002
Student Hell Headingley
Running Vista Ultimate SP1 and IE7 on an old FX53 cpu machine @ 2.4ghz.
Mostly ok but IE keeps either taking ages to swap pages or locking up altogether anyone else suffering? any ideas?
I was having problems trying to favourite pages yesterday. So copied links to notepad, closed all tabs and restarted. Problem returned after a while.
its been doing this here for about 2 months now, my have been an update thats the problem, i dont know
Yes ie7 become anoying and freezes up often. IE8 has that issue fixed here.
IE8 still doing it here
sounds like you're using IE..
switch to Firefox, and install ablock plus, then choose 'easylist' subscription
for fast & clean browsing
Yes I have been having this too and it is caused by Flash Player 10. Something which Youtube forced me to install a month or two ago.
It would appear that Adobe have fallen out with Microsoft to such an extent that they have now started introducing serious bugs into their IE add-on and coordinating their efforts with Google-owned Youtube in order to alienate users of IE and cause them to seek alternative web browsers.
Given how utterly dire the nsPlugin version of Flash is and has been for years (not to mention IE's market share), that's heading for tinfoil hat territory.
I know. I was just throwing the idea out there really...
It just seems amazing that Flash 10 has been out since what September 2008? And Adobe still haven't fixed glaring stability issues with it when running in IE7/8. What is more amazing is that none of the tech media press seems to have picked up this highly controversial story. I suppose they don't care or haven't noticed because I doubt people like The Register, Inquirer or CNET etc use IE anymore.
Flash 9 was about for years and Adobe hadn't fixed the glaring stability and performance issues with it either :p
If they don't use IE any more, they're probably used to it being dire :D
I never had any major problems like this with Flash 9.
Microsoft need to improve their sandboxing of third party plug-ins. That is quite clear. I hope they fit this in for the IE8 RTM.
It really needs to come up with some sort of dialog along the lines of "Adobe Flash 10 has malfunctioned and this tab has been closed". Otherwise people are blindly just going to assume that it is IE that is crashing rather than the Flash plug-in.
You were using IE though?
Like I said, Flash 9 had all sorts of issues with other browsers (Flash 10 still hammers my laptop's T7200 on iPlayer).
If they're not doing it already (and AFAICS, that isn't there), I hope they're not going to introduce a change like that post-RC1.
It's what Chrome does, though it doesn't really change anything for most users.
I think the best we can hope for is Silverlight and (especially) JS/SVG/SMIL push Adobe into doing something with Flash, or it drops into irrelevance.
