- 19 Feb 2007
- Sol
Friend of mine in work flashed his 780 with a modded bios, Allows higher voltage tweaks of up to 1.2v which is Nvidia's max supported voltage for the 780, 100% fan speed should you so choose instead of the previous max of 80%.
Here's the link for forums, bios downloads, tool downloads etc... - http://forum.techinferno.com/forum.php
You need 5-10 posts on the forum to download the latest NVFlash
And here's a link to a step by step video -
It takes roughly 10 seconds to flash your card then you reboot and then there you have it
So far I've managed 1202/3206 stable and also 1202/3405 but haven't been able to test the latter due to being in work ^_^
*EDIT* If the power goes out during flashing kiss your card goodbye so make sure you have plenty of electricity on your meter ^_^
