Hi,
I recently got FTTP installed and am looking to improve signal around the house to take advantage of the speeds. I noticed the router I have been supplied (which I am kind of stuck with a bit as ISP won't let me use anything else on a domestic connection) supports 'EasyMesh', which I was hoping to make use of as it would mean the existing router can stay as an AP, and I'd then need two more 'EasyMesh' enabled APs to get signal where it's needed. From a Google around I can't see any obviously available kit that supports EasyMesh, has anyone found/uses kit with it at all?
Obviously I could just disable WiFi on the router and get three mesh APs instead...but am also trying to keep ongoing power usage in mind and so the less devices that need to be on all the time the better! I've already got a modem to power separately now as well as router, where as obviously before with FTTC the modem was built in to the router.
Thanks.
Thanks.
