- 23 May 2006
I have a Sony 65XE9305 gaming TV and when using console HDR looks fantastic.
however on PC it looks so washed out. i have fiddled with tv settings but just cant get it right (compared to PS4pro where it just works)
i have disabled it on desktop as i believe it is a common complaint that it is rubbish in windows but for instance with destiny 2.
parts look amazing, but other areas look washed out. I am convinced it is a settings thing but cant fathom it.
in the brightness settings in destiny 2 there are 2 sliders, and you have to make the middle of 3 icons "barely visable"
the 2nd one, setting up the black scale, it works fine, but on the 1st one, setting up the white scale, no matter what i do all 3 icons are clearly visible. i think this is my problem.... and why bright scenes are washed out.
you would think turning tv brightness down would fix it but it does not seem to be the case. I cant believe i am the only one with issues here, please help. (i am loath to give up on HDR because the parts that work well are incredible imo)
Thanks.
Thanks.
unless you have the exact spec of MS HDR supported HDTV, GPU, Motherboard & cable. I just gave up in the end bought an Xbox1X & got out of the box HDR & can playback 4K UHD HDR discs for less than the cost of the PC UHD Optical Disc drive & Software!
