Diss, unlike USB modems and winmodems (for example), routers are operating system independent. The Netgear (and most other routers) actually run embedded Linux themselves!
When you power them on, Linux boots up inside the router and runs the connection routines. As the configuration of the router is done via web interface (i.e. using your web browser) it doesn't matter if you're running Windows, Linux, OS X or whatever.
As was mentioned, you'll need to find a Linux compatible wifi card if you don't have one already, or else use ndiswrapper to load a Windows driver onto Linux. Netgear cards, and anything with an Atheros or Intel chipset should be fine using Linux drivers
