Anyone good with electrics and lights
18 Jan 2004
Sunny Scotland
Does anyone know what this little block is called. Its from one of the under cupboard spot lights that shine onto the countertop. a G4 bulb goes into the two little holes on the front where the writing is. But the wires that went into the back of it have came off and instead of buying a whole new light I am wondering if this small block can be bought but I don't know what on earth it is.
Its just a lamp holder plane and simple, pretty common fault on lights is the lamp holders go or the wire connection to them.
Could try an electrical wholesaler, but they will probably just flog you some new fittings.
Pics of the fitting would help and where the lamp holder used to fit into it, see what can be jerry rigged etc
If you have the circular ones with frosted glass fronts? the middle often pops out and can be replaced keeping the surround, say if you have those polished steel triangular surrounds, just colour match and replace the centers, check if its gonna fit first tho, they can be tight.
Ps. Im mostly using t5 link lights now for undercupboard / counter lights, bulb last forever and very easy to fit.
pps. You could probably just redo the contacts on that lamp holder but couldn't guarantee a good result which might overheat and burn out so probably best not to do that
Cheers for that bud as I was struggling to find the fitting itself and didnt want to buy a new light I got a neeber to solder the wires back in and its holding and working fine. Moving house so keeping the spend low. Cheers :D
