Anyone got a Eufy C33 smart handle lock? Need some dimensions
19 Oct 2002
Auckland, New Zealand
Howdy folks
Currently running a Sylvan smart handle lock but it requries a wifi extra to make it work remotely and then it doesn't link in to the rest of my eufy system. I'm looking for some dimensions if anyone has one for the smaller outdoor unit. Does anyone know what the dimensions are from the bottom of the unit to the underside of the crossbore hole in the door and then from the top of the crossbore hole to the top of the unit. The existing Sylvan lock that has 2 additional small holes above the main crossbore hole and I need to check whether the outside unit will cover these holes or not.
Thanks!
