OK so since my 360 went boobies up I've had a bit of a think about the PS3 (gotta consider all options right
) but the problem is I've only got a VGA flat pannel monitor to use.
From what I've read it is possible to connect a PS3 to VGA via one of 3 methods.
1) HDMI to VGA converter- way too expensive
2) Composite to VGA box- mixed results, allows monitor to be used for PC also.
3) Composite to VGA cable- allows only single connection to monitor but should be better quality.
Just wondering if anyone is using any of the above methods and if so would they be kind enough to provide pics?
Thanks in advance.
) but the problem is I've only got a VGA flat pannel monitor to use.From what I've read it is possible to connect a PS3 to VGA via one of 3 methods.
Thanks in advance.
Seems i need to switch it to HD before connecting but my tele goes green :O
