Anyone got Fujitsu FDX310 modem and 8 meg connection?
18 Oct 2002
Im with orange broadband (wanadoo) and was connected at 2 meg.
A couple of weeks ago i was having problems with my pc, the internet connection was getting dropped and caused the system to freeze, also a few blue screen errors.
I then noticed that i had been upgraded to 8 meg about 2 weeks ago which was when the problems started.
After trying everything i could think of to solve the problems i decided to try my old speedtouch modem, and with updated drivers for an 8 meg line it all working fine with no problems.
So i can only assume that the Fujitsu FDX310 modem was at fault, it was working fine with a 2 meg line but caused problems with an 8 meg line.
Does anyone have a Fujitsu FDX310 modem and an 8 meg line ?
Ive emailed Fujitsu about the problem, but got no response.
Anyone help ?
Thanks
You just noticed you were on 8Mbps? :confused:
Some of us have been fighting for every speed upgrade possible! :mad: I can only get 2.5Mbps max and I check it daily in hope that I will be on 4Mbps inline with the rest of the country. :mad: :(
/Rant
Speed upgrades do cause problems with modems and routers, when I went from 512Kbps to 1Mbps my router would often give up.
Sometimes you have to buy a new modem, e.g the infamous BT frog modem.
Yeah i know! I used to check my connection speed every so often.
I got upgraded to 2 meg and was happy with that.
I think it was down to the fact that i had just got back of holiday and i was trying to work out what was causing the connection to drop, and then i noticed!
