anyone got hel brake lines (are they worth it?)
6 Apr 2011
well as the title says really I have been looking into getting some hel brake lines front and rear I know they look nicer than oem ones but do they offer much more in the way of feel and performance? and are they worth £70?
I've go them on the front of my GSXR in a racing setup, i.e. 1 line straight to each calliper, rather than going to one then over the mudguard to the other. I noticed the difference personally, in both feel and performance. Not a massive amount, but enough for me to notice.
I wouldn't bother with the rear mind you, more chance of locking up the back wheel, and you'll probably not notice any better performance. Unless it's simply the aesthetic look you're going for?
I have them on all my bikes
Great people to deal with and always there to help when you need it.
Let me know i can do them alittle cheaper for you ;-)
Ohh nice all depends on the price mate would most Likley get both as I hate the look of the rear.
And a race setup on the front (if that makes a difference to the cost)
Race setup is 2 hoses.... 1 to each caliper. most brake setups used to be one to the caliper then a link pipe to other caliper across mudguard so one cable - half the cost.
What bikes it for fella?
I'll call them up later and find out for you.
Most of the time it's cheaper going for the "kit" they do I.E twin lines up front and rear line.
Alright mate thanks its for a 2011 er6f but I am going on holiday tomorrow till the start of August so won't be able to order them until I get back
