If so, have you:
a) Upraded the 6cm side fans
b) Unplugged one or both
c) Put up with them whirring away
As you might quess, I'm finding the chassis a bit noisy. Inside it's got the JNC91-330-LF board in (dual core Atom), 2GB DDR and a single 500GB 3.5" SATA drive.
If you've replaced the fans for something better/quieter, any recommendations?
Cheers,
Chris.
Cheers,
Chris.
