Anyone had issues with GTA 1 from rockstar classics pack?
10 Dec 2004
Oxfordshire
mine just seems to crash as soon as i load a level :(
anyone else had same issues or found a fix?
im on W7 Ult btw
Ta
Ben
Yep, on my rig in sig it BSODs when i load the level with a video memory manager fatal error or something like that anyways.
Strangely runs perfectly in my windows 7 laptop tho (both using x64 Ultimate).
Was only gonna play it on the laptop tho, so not too fussed about finding out why it's crashing, since that's the only time my PC has BSOD'd.
Nah, hadn't bothered checking there as I'm not really bothered about it on this PC, but just had a quick look and disabling the second monitor makes it work, for me anyways. Runs perfectly too :).
Cheers :).
doesnt work for me either and im on xp, this isnt exclusive to the steam version though as my old disk version doesnt work and neither does the free download.
I had this problem aswell it is a resoultion issue, well it was for me, i suppose all of you on here will have two or more monitors, well you have to disable the monitors, so that only the primary monitor is on and it should work. That was what fixed the issue with GTA 1.
ok found a fix that works :)
on this page - http://gtamp.com/gta1/
get the GTA fixer and extract to the game directory, run it before you play and its all good, appears the game has a habit of braking its own files lol
if it goes mad again, just run the fixer and bobs your uncle :)
